having a confusing moment
Old May 23, 2011 | 09:33 PM
FlatBlak's Avatar
FlatBlak
trying to figure out speedometer gears... running a c6 with 3.55 gears, 28 inch tire. how do i figure this out and do i just change the gear thats on the speedo cable or do i have to pull apart the trans to change both of them?
Old May 24, 2011 | 07:42 AM
nstueve's Avatar
nstueve
use the calculator to figure the number of teeth you need on the speedo gear...
Ford Bronco Speedo Gearing
Old May 24, 2011 | 03:29 PM
FlatBlak's Avatar
FlatBlak
thats whats confusing me is those stupid calculators
Old May 24, 2011 | 03:48 PM
Conanski's Avatar
Conanski
It helps a LOT to know what driven gear is on the end of the speedo cable now and also what way your final drive combo changed.. more or less gears, bigger or smaller tires from the stock combo.
Old May 24, 2011 | 04:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
basically you will need to know how far off your speedo is, and what gear is in there. with that info, we can give you the proper gear to get.
Old May 24, 2011 | 05:37 PM
FlatBlak's Avatar
FlatBlak
so theres more to it? how would i figure out how much its out? the gear you guys are talking about is the one that goes into the transmission on the end of the speedo cable right? i have to count the teeth on that one? but im changing transmissions so what if the internal one has a different tooth count?
Old May 24, 2011 | 05:58 PM
tjc transport
i ain't rite
nope, nothing to it.
before you put the cable in the new trans, count the teeth on the speedo cable gear.
after you get the new trans in, use a gps unit to figure out how far off the speedo is, then let us know what gear you have and how far off the speedo is. we will then be able to tell you the proper tooth count for the gear you need .
therigwelder
Sep 22, 2013 08:05 PM
ufvj217
Nov 22, 2012 02:30 PM
FordNFishinLover
Jul 4, 2009 01:15 AM
redbull660
Modular V10 (6.8l)
Apr 22, 2004 03:38 AM
CJay
Mar 16, 2000 05:38 PM
