So what do I do now?
Old May 23, 2011 | 08:04 PM
73stang's Avatar
73stang
Rev-X helped greatly with my cold starting issue, leading me to believe I have some injector stiction. But I have a few questions nonetheless
I've heard that Rev-X doesn't always help forever....true?
Will I have to keep adding Rev-X in the future (every oil change)?
Should I run synthetic oil? Maybe lighter weight too (5w40) ?
Should I get a re-flash for inductive heating to help further?
If the problem gets worse....Do I have injector replacement in my near future?
Thanks guys!
Old May 23, 2011 | 08:23 PM
mah77's Avatar
mah77
True.
Most likely, but not every oil change. Try every third first.
Dunno, sorry
Maybe, maybe not, but as long as the Rev-X helps....
Answers in blue. I had a slight stiction issue with mine. Its been approx 8000 miles since I added it, and the problem hasnt returned yet.
Old May 23, 2011 | 08:27 PM
Dieselpop's Avatar
Dieselpop
Thanks guys!
Boy just need a little info on the truck
What oil are you running now Dino or Syn Ford filters
How many miles on it
NO you should not need to us all the time
Most of the time on a flash you may drop in MPG
How are your Batteries
Have you check the FICM
When did you change fuel filters last Ford only
pop
Old May 23, 2011 | 08:39 PM
73stang's Avatar
73stang
pop
Early 2003 6.0l 113k miles. FICM batteries are OK
Shell Rotell 15w40 non-synthetic changed 200 miles ago with OEM filters (OEM fuel filters too)
Old May 24, 2011 | 01:01 PM
steelhead2's Avatar
steelhead2
what happened with the coolant loss and wet egr valve?.just curious,usually that stuff dont fix itself.
Old May 24, 2011 | 01:07 PM
High Binder's Avatar
High Binder
Rev-X = band aid
It also doesn't have anything in it (in concentrations necessary) to help reverse the problem it just covers up the problem.
You have an injector replacement coming up.
Old May 24, 2011 | 10:04 PM
73stang's Avatar
73stang
Originally Posted by High Binder
Rev-X = band aid
That's what i was fearing...
Bump for more opinions
2006powerstroke90
Jan 27, 2021 02:42 PM
Truckie256
Feb 23, 2015 01:13 PM
Ford11
Sep 18, 2014 10:21 PM
2006powerstroke90
Jun 25, 2011 02:39 AM
DoneDunIt
May 10, 2010 08:44 PM
