Air Intrusion
Old May 23, 2011 | 07:35 PM
FordManiac88's Avatar
FordManiac88
Air Intrusion
So I've got air intrusion in my fuel line and have tried to search the remedy but didint find too much, I was kind of hoping for a "how to" kinda dealy. Any one know where I can find the parts and what the job entails?
Thanks!
Old May 23, 2011 | 08:08 PM
gatormccluskey's Avatar
gatormccluskey
First check the rubber hose at the lift pump. Then check the return lines on top of the motor.
I took a garden sprayer and hooked it to the bleeder valve on the filter housing. Take out the small valve and connect a rubber hose from the sprayer. Put a small amount of pressure on the sprayer. Look for air bubbles. Mine looked like a sprinkler. That is a good start.
Old May 24, 2011 | 05:08 PM
FordManiac88
There is fuel leaking down the rubber hose and fuel seems to be settling on top of the engine. Do I have to get the parts from International?
Old May 24, 2011 | 05:15 PM
tecgod13's Avatar
tecgod13
Do a search for return lines or injector return lines. There are many posts on this exact problem (air intrusion) so I don't know why you didn't find any... I think wreckinball did a very nice step by step, but I might be mistaken on the user name.
You need to replace the injector 0-rings and return lines. The parts can be bought from many places. My opinion is get the #111 viton o-rings from mcmaster carr, the proper size fuel hose: 1/4" for later trucks with the offset nipples, 5/16" for all 6.9's and earlier 7.3's with nipples inline with the injectors.
Unless they are cracked the plastic caps are most likely reusable, though the whole kit is pretty cheap. Use something to lubricate the rings before installing.
Old May 26, 2011 | 08:40 PM
gatormccluskey
I got the kit from NAPA for about $60.00. Line - O-rings - caps.
Old May 26, 2011 | 09:23 PM
FordManiac88
Oh man thanks for the help yall. (Noobie diesel owner here)
The fuel was leaking directly out of the rubber hose and because of gravity and wind it sprayed everywhere so I figured it was leaking in more then one spot. I wiped everything down then started the truck and traced the leak specifically.
A four inch, 5 dollar length of tube was stopping my truck from starting
Ah well haha glad to know it wasn't major.
Cowboy9215
Nov 9, 2014 06:44 PM
Onus
Oct 16, 2012 01:13 PM
Forddiesel17
Dec 1, 2011 01:53 PM
why165
Oct 28, 2006 09:17 PM
greinercon
Jul 6, 2002 02:47 PM
