Ticking motor
Old May 22, 2011 | 09:25 PM
cadetspider06's Avatar
cadetspider06
Question Ticking motor
Update.
All is back together with new exhaust gaskets. No more exhaust leak.
The major tick was coming from a broken spark plug (2). The steel and ceramic had seperated.
All is well again. Its time for a beer!
I have an 88 f150 with the 4.9 and within the last week it has developed a rather loud valve train tick. And upon startup, chokes and dies. I suspected a loose rocker, but when I pulled the valve cover, all appears to be tight. The only thing I noticed was an appearence of burned oil caked on #6 intake and exhaust rocker.
My question is can I replace just that cylinders lifters or do I need to change them all?
Would I also need to change the push rods with new lifters?
What is the best way to adjust the valve lash after installing the new lifters?
ETA: I ran the motor to see if the rockers were getting oil and they are. There was also no audible tick with the upper intake and valve cover removed.
Any Ideas?
<!-- / message -->
<!-- controls -->
Old May 22, 2011 | 11:03 PM
Joeseph's Avatar
Joeseph
Have you checked for exhaust leaks?
Old May 22, 2011 | 11:53 PM
cadetspider06
It has an exhaust leak from the donut gasket. It has had the leak since I got the truck.
The engine tick is much worse
ETA: Also with the new ticking comes engine dying after start up. It starts, sputters and dies. Once I get it running, it seems to run pretty good, aside from the loud tick
Old May 23, 2011 | 12:09 AM
Joeseph's Avatar
Joeseph
If the thing had a exhaust leak and the ticking has gotten louder first fix the leak then determine if its something else.
Old May 23, 2011 | 12:11 AM
cadetspider06
I can still hear the original leak.
Old May 23, 2011 | 12:12 AM
cadetspider06
I can still hear the original leak, but I will take care of it with this one.
Old May 23, 2011 | 07:30 AM
billt28's Avatar
billt28
Exhaust leak? Try replacing the exhaust to manifold gasket, and see what you get. Make sure you torque the manifold to the proper ft. lbs., and sequence.
Old May 23, 2011 | 08:14 AM
cadetspider06
Is a lifter problem not common?
Old May 23, 2011 | 08:20 AM
cadetspider06
I will work the exhaust angle tonight. Weather pending.
Old May 23, 2011 | 08:40 AM
AbandonedBronco's Avatar
AbandonedBronco
It definitely could be a lifter, but an exhaust leak can sound like a lot of different mechanical problems. Plus, an exhaust leak can get worse over time.
If you know you have an exhaust leak, tackle that first. That way, you can know for sure if you have other problems when it's done.
Old May 23, 2011 | 12:14 PM
cadetspider06
I will fix the exhaust tonight. I jsut dont want to break any bolts off in the head
Old May 23, 2011 | 05:23 PM
billt28's Avatar
billt28
Torque them to the proper tightness, and in the proper sequence and you won't have any problems.
Old May 23, 2011 | 07:07 PM
AbandonedBronco
I think he's more concerned about snapping one when removing them, especially if they've never been removed before.
Old May 23, 2011 | 07:26 PM
Harte3's Avatar
Harte3
I've not had a lifter problem but several times have had the donut leak problem and that was the source of the "ticking". If the gasket is not holding for very long then suspect a plugged/dirty cat converter as they can cause enough back pressure to blow the donut.
Old May 28, 2011 | 05:04 PM
cadetspider06
I also suspect exhaust. The egr tube was loose upon upper intake removal. I have been idle on the fix due to a death in the family, but monday will be go time.
Is the egr system necessary on this motor or can I delete the system?
