laid my gauges down...
Old May 22, 2011 | 08:37 PM
xc4jokestomper's Avatar
xc4jokestomper
i recentl tilted my gauges too far and now my gas gauge, oil, water, and voltage gauges dont work.. what are my options here? anyway i can fix them or do i have to buy new ones? what would you all do?
Old May 22, 2011 | 09:21 PM
perk40's Avatar
perk40
What do you mean by tilting your gauges too far. I have pulled mine several times and laid them down different directions with no issues.
Old May 22, 2011 | 09:27 PM
xc4jokestomper
Ive read before that you cant lay your gauges down flat because there is some kind of fluid in them that messes up. Either way mine arent working
Old May 22, 2011 | 10:20 PM
So-Cal Sancho's Avatar
So-Cal Sancho
i've heard of this too. I havent expierienced this even when i swapped out my cluster for one with a tach. it was shipped from florida, and i thought about that happening, but i looked at them i didn't see any fluid anywhere on the the new cluster or old cluster. i dont know where it would be but i tilted mine all sorts of ways front, back etc and they still worked. dont know how to fix it, except replacing.
Old May 23, 2011 | 01:40 AM
SideWinder4.9l's Avatar
SideWinder4.9l
The SPEEDO has Anit-Vibration fluid in it to prevent a floppy/jumpy speedo hand....the rest, to my understanding aren't susceptable to the whole laying them face down issue.....
Clean, and check the probes/connectors...
Old May 24, 2011 | 09:42 AM
xc4jokestomper
Well my left hand blinker works fine? Just the gauges left of te speedo doesnt work now. Is the blinker and those gauges plugged into the same power source?
Old May 24, 2011 | 09:48 AM
SideWinder4.9l
Should be 1 plug for each panel of the cluster....
Old May 24, 2011 | 05:52 PM
xc4jokestomper
Yeah theres three plugs. But does the left hand blinker controlled by the left hand plug in? Because the blinker is working and would mean that their plugged up right?
Old May 24, 2011 | 06:28 PM
White 97 xlt's Avatar
White 97 xlt
the plugs should be Keyed and ONLY plug in where it is supposed to go...
Old May 24, 2011 | 07:08 PM
jimbo285's Avatar
jimbo285
I removed my cluster in 96 F250 and tipped upside down. The speedo needle ended up pegging out at 85 or whatever and I didn't notice until i put power back to it. Now my Speedo jumps like crazy 10mph fluctation at 30 mph or so on up to highway speed. I think it was a cooincedence, but you never know. I heard about the anti-vibe fluid but i don't think it's true in modern instruments. I've checked wiring several times since and it still happens.
Old May 24, 2011 | 08:41 PM
xc4jokestomper
I know i have the plugs matched up right. I was just wondering if the left side gauges and blinker are controlled by the same plug? Because that blinker works and if that blinker works that means their plugged up right.
Its like their stuck at where they were turned off. The gas gauge is at full, the water temp is in the normal area but the other two are like when the truck is turned off.
But my speedometer is working fine
Old May 25, 2011 | 10:22 AM
hivoltj's Avatar
hivoltj
You probably don't have the LH plug in all the way!
Old May 25, 2011 | 11:52 AM
xc4jokestomper
Ill pull it out today and take a look. Ill get some pics up today as well. Im finally off work. Leaving at 6:30 in the morning and getting home at 10:30 at night makes it kinda hard
Old May 25, 2011 | 03:51 PM
xc4jokestomper
well i got home and pulled it out and guess what, not plugged in all the way! i cant thank you guys enough. i dont know what i would do without this site lol. anyways i posted some pics in the dash gauge bulb thread of how mine turned out and all that good stuff.
Old May 26, 2011 | 06:12 AM
TexasGuy001's Avatar
TexasGuy001
All the gauges have the dampening fluid in them. Although that should not cause them to not work, they may just be jumpy or not smooth.
tjustice
Jul 23, 2012 08:42 PM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 1, 2010 07:57 PM
texas fling
Apr 24, 2009 02:57 PM
63DH8
Mar 24, 2009 12:20 PM
mjlewis
Oct 17, 2006 03:09 PM
