Resistor wire
Old May 24, 2011 | 06:47 AM
Ryank78shortbed's Avatar
Ryank78shortbed
No I got about all the tape peeled off last night just to visually inspect the wiring and everything! Was planning on digging deeper into it tonight! Thanks for all the help!
Old May 24, 2011 | 06:50 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Originally Posted by fmc400
The positive (+) terminal of the coil from the engine bay branches off to two places - BROWN, which is hot-in-START from the 'I' terminal of the solenoid, and the RED/GREEN resistor wire which is hot-in-RUN from the ignition switch. The RED/GREEN wire (where it's marked as a resistor wire) acts as the ballast for the coil when in RUN, the BROWN wire bypasses the ballast while the motor is turning over.
Have you checked the primary winding resistance of your coil yet? It's almost impossible to solve electrical issues without a multimeter. If your wiring checks out, the coil might be shorted internally.
Saved me some typing. Two points. 1)It is normal for the resistor wire to be warm, just not overly hot. 2) Everything originates at ignition switch. Assuming it is a 78, should be a DSII ignition so you will find two more wires tied in, feeding the ignition module. Both before the resistor wire, at or near the ignition switch. I don't have diagrams for past 77, except the ignition wiring.
Old May 24, 2011 | 06:52 AM
Ryank78shortbed
Yes your correct its a 78!
Old May 4, 2015 | 03:01 AM
shaker666's Avatar
shaker666
I've fuel injected my '79 Bronco and I had this resistor wire start smoking on me recently. Initially I thought it was a fusible link, but it's quite clearly the pink resistor wire that reads "RESISTOR DO NOT CUT." Since I'm running EDIS8 coil pack ignition and a computer, can I simply cut this resistor wire out completely and replace it with standard copper stranded wire?
Old May 4, 2015 | 11:28 AM
ZarK-eh's Avatar
ZarK-eh
Depends on the system you placed in. If it's able to handle the full 12 volts without a resistor then yes, replace the resistor with a standard stranded copper wire. Also wire in a Fuse holder for a 10 Amp Fuse.
When I fuel Injected mine, I use a chrysler minivan wasted spark coil pack and the resistor wire smoked like yours. I had to dig out the wiring diagrams for the minivan and the coil did not use any resistor, wire or ballast. Then on the Starter Relay/Solenoid remove the "I" Terminal plug as it's not needed anymore.
perljammike
Jun 16, 2016 09:50 PM
62 ford owner
Dec 30, 2015 03:48 PM
jyates2007
Oct 18, 2015 11:24 PM
Pastor Dale
Nov 21, 2014 01:00 PM
hogrydr
Modular V10 (6.8l)
Apr 12, 2010 08:42 AM
