Center TTB U-joint repacement?
Old May 22, 2011 | 09:03 AM
pintoches's Avatar
pintoches
83 Dana 44 TTB Trying to change the center U-joint on the axle, Got the outer shaft out but could not get the inner shaft from the diff? How does it come out?
The Haynes book shows early externally retained axles don't have c clips, later internally retained axles do have c clips? Is there A year that this changed? How can I tell for sure before I pry on this to much?
Old May 22, 2011 | 06:40 PM
pintoches's Avatar
pintoches
Got the Axle out along with the seal bearing and a spacer that was stuck to the axle out. It all came out as one piece and, I stuck it back in as one piece! all went back together easy! Did some 4 wheeling afterwards!
Old May 22, 2011 | 07:33 PM
pintoches's Avatar
pintoches
The camera is never out when the cool stuff happens, thought I would still share video,
Jacksonfarms
Jan 26, 2016 07:07 PM
1984F2506.9
Dec 4, 2014 11:32 PM
warmdye
Mar 12, 2011 09:16 AM
BURNSTOUGHFORD
Nov 17, 2009 03:39 PM
fordor
Oct 22, 2006 11:41 AM
