Another no cruize / horn question...But THIS is odd.
#32
Build Data: 10/94 Canadian built
In case someone else runs into this wierd shi! here is the wire colors. Hard to tell from the photo.
Disregard my color wires, I used them to test it all, I still need to wire it up more properly. Starting from the steering column light grey square plug to the black rectangle plug on the factory harness:
Yellow wire goes to dark blue wire - Horn
Dark Blue/Black wire goes to Light Blue/Black wire - Cruise
Passenger side Black goes to Green/Orange wire - ground.
Driver side Black goes to black/white wire - Key in Chime.
Not sure how the count 4 cruise buttons from the steering wheel are controlled from one or two wires but it does.
#33
#35
The cruise works with 2 wires, one goes to the set/accel and the other goes to resume/dec. The wires get 12v from the horn circuit, and return different ohms depending on which button you push to tell the cruise what to do. Thats how i understand it anyway, I could be wrong.
#36
No problem, i've been lurking on this site for years, learning a lot, its nice to finally contribute.
Look what i found- https://i.imgur.com/bjUEV.jpg
I was going to fix my column bearings a few months ago, my buddy told me to take the column out of the parts truck he had in his yard, so i just swapped them. His was a '92 F-150, mine is a '95 F-350. I had to switch the plug from my column to the donor column. I wish i had remembered this earlier, would have been easier for you! If you like, i could send you this plug from the '92 , i'll never need it. You could just switch the wires so you dont have to hack yours apart, if you havent yet.
#37
Well I'll be, thats the same plug. Is that from the 92? Sure makes me wonder why my column was switched out though...There are no signs of a wreck.
I sure appreciate the offer, but I think I'll try to fin a way to make a new plug. I've got lots of stuff laying around here. I'll prob use a computer 4 wire male/female plug. BTW cruize works great and is nice to have on the freeway stretches.
#39
on
hey guys!
iv got no ground coming out of that clip down low thats shown.any idea's?
everything i have at the clip,i also have up at the horn/cruise buttons.
no cruise,no horn.
i put a ground jumper on the copper switch bracket and got a horn this way,but still no cruise still going down the road at any speed.
what goes bad further up the line that brakes ground,and if bypassed via a jumper ground,only results in a horn and not cruise?
hmm.i think i need to search "cruise servo testing" now.
wrong thread again i think boys lol.i figure this out.........hopefully.
i can't find what i need.
no cruise,no horn.
wevie
13
11-02-2016 06:13 PM
RaventreeJohn
02-15-2016 01:24 PM
427 fordman
12-07-2015 11:35 AM
