Trans shift linkage loose
Old May 20, 2011 | 08:47 AM
bigbubba87's Avatar
bigbubba87
The transmission shift linkage is loose inside my trans on my 4r100 is there any way to tighten it up?
Old May 20, 2011 | 08:59 AM
mueckster's Avatar
mueckster
Is it rotational slack or 'in and out'? Did it happen all of a sudden?
Name:  4R100 internal linkage.gif
Old May 20, 2011 | 10:04 AM
bigbubba87's Avatar
bigbubba87
Its rotational. An it gradually happened I didnt notice it until a few days ago
Old May 20, 2011 | 11:26 PM
mueckster's Avatar
mueckster
Name:  4R100 manaul lever detent spring.gif
#1 is the nut holding the detent plate to the shaft
#2 is the manual control shaft
#3 is the detent spring with a roller on the end of it that rides in the notches of the detent plate
There may be a problem with the spring or the bolt loosened up holding it.
bopfly
May 16, 2016 09:26 AM
domifan
Nov 10, 2015 08:36 AM
stork1971
Dec 30, 2014 05:17 PM
abyars111
13
Aug 22, 2013 10:33 AM
MMSCHWE
Escape & Escape Hybrid
Dec 3, 2010 06:32 PM
