Sponsored by: Real Truck
Towing
Old May 20, 2011 | 07:42 PM
redford's Avatar
redford
FTE Leadership Emeritus
I tow my classic cars in a 28 foot enclosed car hauler. Trailer weight is around 8000 pounds. My truck (see signature) does fine. Use Tow/Haul mode and enjoy the drive.
When I picked up my trailer the guy who ran the business showed me a real easy way to tell if you are loaded properly. Hook your trailer up to your truck, then lower your trailer tongue jack so it is roughly 1 inch above the ground. Load the vehicle while someone watches the tongue jack. When the jack reaches the ground you have about the right tongue weight for your load.
Old May 20, 2011 | 08:36 PM
exiled's Avatar
exiled
Good ones. So is that saying that the truck should only squat an inch? I'm going to try it out tomorrow.
Old May 31, 2011 | 12:23 AM
GeneLaw1's Avatar
GeneLaw1
Thanks a lot for all the helpful advice on towing. unfortunately I didnt get a chance to even tow the car this weekend because of mechanical problems with the car, and the expense of renting the trailer, I just figured in the end it wasnt worth it.
Old May 31, 2011 | 12:25 AM
GeneLaw1's Avatar
GeneLaw1
I think what I may do is invest in an enclosed trailer as Redford did, it seems like a great option to get those classic cars around...
Old May 31, 2011 | 05:56 AM
redford's Avatar
redford
Not exactly. It should squat an additional inch when loaded. You will get some squat from the trailer itself.
Old May 31, 2011 | 08:56 AM
Monster-4's Avatar
Monster-4
I would suggest you look into a weight distribution system as well. Ford says it's a requirment above a certain trailer weight and tongue weight. Not using one won't mean you truck will burst into flames but I find towing more enjoyable with one especially and enclosed trailer.
I personally like and recommed the Equal-I-zer brand hitches. You can find a 10K/1K model new from RV Wholesalers for $440 shipped. You can also hit Craigslist and Ebay. I found mine used on Craigslist for $200.
Old May 31, 2011 | 02:06 PM
exiled's Avatar
exiled
Yea I just ment. What you load on the trailer lowering the truck another inch.
I've tried it and works good. However it has my tractor slightly more forward than what I like. Which is no big deal but I have a FEL and I'll have to raise it up or something else. If I'm not loading the bushhog also I've been known to back the tractor on the trailer and that's when it'll came in handy. Only problem most of the time I don't have anybody to watch for me. I've learned how to load my trailers over the yrs through trial and error.
Old Jun 1, 2011 | 12:20 AM
Artemus Gordon's Avatar
Artemus Gordon
I tow a 33 ft travel trailer. Check out RV Net, lots of great towing advice. I have learned much from these guys. What I learned was "take it slow"! Also I use a "Equalizer" Hitch and even with my big truck it helps stop any possible sway. It's not really necessary if it's just s one time tow. If you buy a trailer in future invest, in a weight distribution hitch.
weaver79
1997 - 2003 F150
Nov 18, 2010 12:08 PM
jfboy
Sep 3, 2007 10:04 PM
bigric
All Things Towing
13
Aug 12, 2003 04:52 PM
Rugby3
Apr 5, 2003 02:17 PM
factofiction
Sep 4, 2002 11:15 AM
