Front Brake Problem on 2000 Ranger
Old May 19, 2011 | 07:56 PM
mattd860's Avatar
mattd860
My father's 2000 Ranger 4.0 4x4 is having front brake issues. He is in the middle of traveling from Connecticut to Indiana and called me to say the front brakes practically lock up even if he just lightly presses on the brake pedal.
What could cause this to happen? If there is a blockage in the rear brake lines could it cause all the force from the master cylinder to be applied to only the front brakes? Like I said, even if he taps the brakes, the front wheels almost lock up and both front wheels are now black with brake dust.
I'm was already planning on traveling out there to meet up with him this weekend so I would like to gather some ideas and more information so we can possibly fix this once I see him. Hopefully we can resolve this before he has to drive all the way back.
Old May 19, 2011 | 08:20 PM
Rackster's Avatar
Rackster
Touchy Touchy
Matt,
Have a look and see if this gives you any ideas. https://www.ford-trucks.com/forums/1...p-in-rain.html
Regards,
Kevin
Old May 19, 2011 | 08:38 PM
greenpus's Avatar
greenpus
slider pins stick and cause the caliper/pads to drag which might be causing some issue. if there is a lot of black powder than that might be it.
remove the pins and grease with high temp dielectric grease. Don't use brake grease. Brake grease will destroy the rubber boot on the slider pin
SuperDutyScaler
2004 - 2008 F150
Sep 1, 2015 08:59 AM
Diesel 724
Jan 10, 2015 06:18 PM
bbdano
26
Oct 10, 2014 10:22 AM
stonerboys
1997 - 2003 F150
Jan 30, 2014 06:28 PM
F-250 restorer
Oct 14, 2010 04:59 AM
