1986 EEC-IV engine computer
Old May 19, 2011 | 03:28 PM
billt28's Avatar
billt28
You need an OBD-I code reader I believe.
Old May 19, 2011 | 03:33 PM
Grubbworm's Avatar
Grubbworm
I got mine at Harbor Freight several years ago for $35, if I'm not mistaken. And OBD I is correct.
Old May 19, 2011 | 08:11 PM
ctubutis's Avatar
ctubutis
Here is how to read codes without a code reader:
Ford Fuel Injection
Ford Ranger/Bronco II EEC-IV Testing
Old May 19, 2011 | 09:58 PM
Galendor's Avatar
Galendor
I got one of these: Kastar Ford EEC-IV reader (link below). It is not a hand-held instrument with a digital readout, it is just basically a blinker light attached to wires/connectors that make it simple plug and play to hook up to the code-delivering plugs on the truck. Since you can read these codes with just a voltmeter and some wires, this thing does the same thing but makes it more convenient. Its advantage is it is small, lightweight, and cheap. It comes with good instructions for use.
I haven't used it yet because my truck is running great and I figure that pulling codes would just create worries. Kind of the same principal that advises you should never, ever pattern your shotgun.
FORD EEC-IV DIAGNOSTIC ANALYZER MADE IN USA KASTAR | eBay
Old May 19, 2011 | 10:41 PM
ctubutis's Avatar
ctubutis
Myself, I tend to wonder & worry more when I *don't* know if there's something needing attention and can be made better. Being blissfully ignorant is just an excuse to not take responsibility.
I pulled the codes on my DD a few weeks ago and learned my TPS was bad and it was THAT that was causing some weird idle problems at times.
Old May 19, 2011 | 11:01 PM
Galendor's Avatar
Galendor
You are right ctubutis, of course. I can't defend my position from a logical standpoint! I do plan to pull my codes soon (shudder).
Old Feb 27, 2017 | 10:25 PM
Toddster's Avatar
Toddster
I know this is an old thread but I have an 86 with the inline 6 and I couldn't find a computer or an "eca". Is it behind the driver's side kick panel?
Old Feb 27, 2017 | 10:27 PM
Toddster's Avatar
Toddster
Old Feb 27, 2017 | 10:57 PM
vjsimone's Avatar
vjsimone
Do you have a 3.9L (240ci) or 4.9L (300ci) ?
Old Feb 28, 2017 | 07:21 AM
Toddster's Avatar
Toddster
i have the 4.9
Old Feb 28, 2017 | 08:21 AM
Franklin2's Avatar
Franklin2
I am not positive, but I think it's mounted up high over the trans hump under the dash.
Old Feb 28, 2017 | 08:58 AM
Toddster's Avatar
Toddster
Ok. I'll look I'm just hoping I didn't fry it with that starting problem I'm having.
Old Feb 28, 2017 | 12:47 PM
  #28
1986F150six's Avatar
1986F150six
To the left of the ash tray. It is mounted vertically.
Old Nov 18, 2023 | 06:05 PM
  #29
Bigdaddy2134's Avatar
Bigdaddy2134
1st Gear
so I have a 1986 ford f250 7.5l where is it located at
Old Nov 19, 2023 | 12:49 PM
  #30
vjsimone's Avatar
vjsimone
I don't believe the 7.5L was fitted with EEC until 1988.
I'm guessing you have the Duraspark ignition system wired up to your distributor & coil.
I believe the ignition module is mounted on the drivers side fender apron.
