I bought a 2006 6.0 with 74K on it 3 months ago. since then I have put 3k interstate miles on it. It is chipped with a dr performance, and air raid intake. the truck runs good, (doesn't smoke )but when I tow and need to pass or climb a hill, the the boost comes up to 28-30 and rpm's increase, but it feels like it should have more power, soon after the pass or hill climb it throws a P0299 code,(low boost) it also says miss fire and 02 mon fault..help!
P0299 can be over/under boost. You are a little high for a stocker. I had the same code and had to replace the turbo. Take the previous advice and go back to the stock intake.
(2004 & 2005 MY only) will be set if the difference between EP_G and EP_DES
meet any of the following conditions:
Greater than 14 kPa or 2 psi with RPM below 800 for 15 seconds
Greater than 20 kPa or 2.9 psi with RPM between 820 - 1995 for 30 seconds
Greater than 80 kPa or 11.6 psi with RPM above 2000 for 90 seconds
