in frame fuel pump
Old May 19, 2011 | 07:29 AM
KawiRider78's Avatar
KawiRider78
in frame fuel pump
i was wandering if i could use the in frame fuel pump off a 86 f150 efi 302 motor and use it for my carberated 302 motor and it is a 600 cfm carb
Old May 19, 2011 | 07:36 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Not a good idea, the frame mounted pump is a high pressure Bosch, somewhere around 65-70psi or higher internal relief valve. You can get one of the low pressure electronic fule pumps if your engine doesn't have the provision for a mechanical pump.
Old May 19, 2011 | 08:10 AM
KawiRider78
ya mine is closed off where you would put a mechanical pump but how much lower are we talking and is there a certain one you would recommend
Old May 19, 2011 | 09:08 AM
85lebaront2
Just about any of the ones either Autozone, Napa, Advance etc. sell. Is your truck originally an EFI truck? If so, you can use the low pressure pump in the tank(s) with a pressure regulator. Carburetors use 5-7 psi.
mitchgordon96
Dec 23, 2014 08:29 PM
merc2dogs
General Automotive Discussion
Mar 26, 2014 09:29 PM
66sprintw53
Nov 2, 2010 04:42 PM
cgi2099
1978 - 1996 Big Bronco
Jul 20, 2010 09:52 AM
ADSf100
18
May 2, 2003 08:43 PM
