f550 ford diesel dump truck having major braking issues HELP
Hello Everyone.
We have a 99 f550 dump truck that has all new brakes = rotors - pumps = etc etc That sat for a month and then all of the sudden we can not get the brakes to work properly, We bled the brakes and put on the above items with no luck!
The truck will stop but the pedal goes to the floor and if the engine is not running the pedal pumps up and stays stiff like it should, Then as soon as you start it up and hit the brakes it goes to the floor! This truck does the same thing now even adding the new items to it plus bleeding it so now we are lost!!
The problem happend after is sat for a month? Any idea what we should?
gartlesby
10-24-2015 10:29 PM
