lost all electrical power
Old May 19, 2011 | 08:24 PM
bronco power 79's Avatar
bronco power 79
i have a 79 bronco with 351M and i just had it painted about 3 weeks ago
stripped down new pannels and all looks great
I havent drove it in 2 weeks cause of work travel got home on a sat afternoon and went to get a case of beer and fired up fine went in got case and came out no start went got new started fired right up then died so i charged battery with a jump after 10min got it started aand drove home with almost no lights
took battery to napa and check battery said was good
i got new alternator and coil
i went to put battery cables back on and i think i had a wire fall off the back of alternator and i think grounded out the old coil. i put the new one on also with a new ignition modual
Now no power anywhere im lost and fustrated
Old May 19, 2011 | 08:31 PM
montana_highboy's Avatar
montana_highboy
Check fusible links coming off battery side of starter solenoid.
Old May 19, 2011 | 08:35 PM
bronco power 79
is that a square metal thing connected to the solenoid along with the power wire to battery???
Old May 19, 2011 | 08:42 PM
montana_highboy
It should look similar to this...
Old May 19, 2011 | 08:48 PM
bronco power 79
thank you
ill have to look for it tomorrow there is a piece on the side of the solenoid that looks like a fuse do you know what that is ??? its in a galvo cover??
Old May 19, 2011 | 08:51 PM
montana_highboy
It sounds as though maybe a PO replaced the fusible link at some point.
Old May 19, 2011 | 08:53 PM
bronco power 79
ok thanks ill try tomorrow
thanks for the help
blp59901
Escape & Escape Hybrid
Jul 29, 2016 07:41 AM
LARIAT 85
Mar 31, 2016 11:39 AM
68bluebeast
Nov 5, 2015 02:49 PM
fiddlesticks
Apr 28, 2014 08:39 AM
Foryota
Nov 14, 2012 03:31 PM
