I'm having intermitent no start problem , when it happens the only way to start is spraying some fluid on the intake .
The voltimeter show error when I check the voltage on pin 4 with 2 differents FICM . the engine runs great with no codes.
I'm suspecting something on power supply , the logic fuse is ok and there is power. does somebody know how to test the power on the 12 way connector?
thanks for help
FICM ok - intermittent NO START conditions- engine never stall and runs great with no codes- yestarday it start in the morning, start all the day and fail to start at night after seating for couple hours during dinning at friends house- In the event of No start I make it run sprayin some fuel on intake so it start nice , I can drive it without any problem and if I turn off it will start normally again . I have no idea what to check -
When I gaot home last night I plugged the scanner and it show me the code P2623 but the check light was off all the time . thanks for help
Not sure if it sets off a code or not, but my 05 6.0 intermitant no start was a bad cam position sensor eventually went out totally. priced out from $30 to $130
