NEW FICM, WHAT NOW?
NEW FICM, WHAT NOW?
Last weekend figured out my FICM voltage was way low so I got a flashed FICM from swamp. I also loaded a Innovative tune from Eric. Got the FICM from FEDEX yesterday and installed this morning.
The new FICM solved the start up, rough idle and zero power issue. However, when i took it out for a test drive it is doing something new.
Under hard acceleration or WOT it starts to cut out from mid range RPMs and up. If it was a gas engine, i would call it a miss. Tried a different tune, no substantial change.
So, is it possible i damaged one or more injectors running it with a low voltage condition?
Is there something else i should be checking? This is starting to get expensive.
on
As far as diagnostics goes, what do you have access to?
I could see it being a possibility. If you are having such a "high" performance issue, then I would imagine that there would be a code stored in there(injector codes usually don't set off a CEL, or atleast I haven't seen one yet). If you have a cylinder issue such as an injector not performing to par, then it should be logged in there. I would try that first.
on
OTC ZTSE4576 ICP LEAK TEST PLUGS (NO. 10) for International
here the tool to test 03/04 style pump leaks.
