TBC Gain Settings
Old May 18, 2011 | 02:45 AM
ssjrsw's Avatar
ssjrsw
TBC Gain Settings
How much does weight effect gain settings? I just installed a factory TBC to my 10 F150, if I find a setting, let say 6.0 on an empty car hauler will that be OK after it is loaded or should I be changing setting?
Thanks
Old May 18, 2011 | 07:49 AM
senix's Avatar
senix
need higher gains usually with more wt.
Always check the gain when hooking up and when changing load configurations.
Best way to see how you are is to load the trailer, get up to aprox 25 mph and try it. Do this where you have plenty of room to stop.
Adjust till you are confortable.
Old May 19, 2011 | 12:14 PM
lakedweller's Avatar
lakedweller
You want the truck and trailer to stop evenly. The truck should not stop the trailer and the trailer should not stop the truck. Every load could and will require a different setting. Very the setting till your feel the stop is nearly effortless....
Old May 19, 2011 | 12:33 PM
ssjrsw's Avatar
ssjrsw
Thanks, that is what I figured. I was hoping someone who uses a car trailer could tell me the difference, like add 2 or 3 points more gain. I wanted to avoid having to set it with my new car on the back. Since it is done at a slow speed it should not be that big of deal, I hope.
Old May 19, 2011 | 01:11 PM
senix's Avatar
senix
set it about 5, then see.
Before you pull out use the manual lever to ensure the trailer brakes in fact are working.
Old May 19, 2011 | 07:04 PM
IDMooseMan's Avatar
IDMooseMan
When I have my trailer loaded and hooked up, I make an initial setting, drive 25 mph in a straight line and fully activate the manual brake lever.
If the trailer brakes lock up, I reduce the setting until they no longer lock the brakes.
If the trailer brakes don't lock up, I increase the setting until they do and then back off until they don't.
This process has worked effectively for me.
Old May 19, 2011 | 07:16 PM
HrdDrv's Avatar
HrdDrv
Moose,
Love the phrase on your sig. 'Thank You". And Welcome Home.
Don't want to hijack the thread...
Dan Manning
Baltimore.
U.S. Navy.
USS America CV-66
'77-'81
Now back to your camping thread in progress.
Old May 20, 2011 | 02:44 PM
IDMooseMan's Avatar
IDMooseMan
You're welcome, Dan. "Thank You" back at ya.
Your service paved the way for me to do what I did. It's up to the next generations now.
phydeauxman
May 8, 2016 05:45 PM
mnmwhit
Dec 16, 2012 01:56 PM
danosll
Jun 17, 2011 10:24 AM
LI Happy Camper
6.7L Power Stroke Diesel
Jun 12, 2011 03:10 PM
bkridel
Aug 5, 2010 06:33 AM
