Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
3208 smoke problem
Old Jun 3, 2011 | 02:47 AM
Dennis/Ohio's Avatar
Dennis/Ohio
Originally Posted by rummur s.c.
Fuel timing can definitely cause a smokey engine. Compression check would be high on the list of things to do as well.
Once you know your timing is on, and the compression is there. Then you can start checking injector spray patterns.
At a Ford Truck dealer in the mid 70's I would see many injectors with a bad spray pattern or a drip problem. I don't remember checking compression but these didn't have high mileage back then. I do remember keeping all the slack out of the gears to check timing or it would be way off.
fakesnake
Large Truck
33
Apr 11, 2020 01:09 AM
1985L8000cat3208
Mar 5, 2017 06:37 PM
1985L8000cat3208
Aug 14, 2016 09:27 PM
Allisfordih
Large Truck
May 7, 2016 11:29 PM
jaker65
Large Truck
13
Aug 21, 2015 05:14 AM
