Ignition actuator help
Old May 17, 2011 | 12:39 PM
paulwjax's Avatar
paulwjax
I have an 86 f150 with automatic trans. and a non tilt steering column and need to replace my actuator. I've torn down the steering column to this point
but cant get this ring off to get to the actuator to replace it.
What now?
Old May 17, 2011 | 07:46 PM
ctubutis's Avatar
ctubutis
I did this about a year and a half ago but with a manual-trans and tilt wheel.
I'm assuming you took off the snap ring?
The shop manual says:
Remove the upper bearing snap ring (green arrow) and the (2) T-bolt retaining nuts that secure the flange casting to the outer tube. The picture shows the flange coming straight off.
Edgethis
1978 - 1996 Big Bronco
18
Nov 15, 2017 01:14 PM
kevin316
Oct 13, 2012 05:36 AM
gregstith
Oct 2, 2012 08:21 PM
2007F150FX4
2004 - 2008 F150
Mar 29, 2011 06:34 PM
ParkStreet
20
Mar 22, 2011 08:34 PM
