1978 - 1996 Big Bronco
borg warner 1356 problems
Old May 21, 2011 | 05:43 PM
250sampson's Avatar
250sampson
Okay so if the transfer case takes a crap it will effect the drive no matter if its in 2 or 4
Old May 21, 2011 | 05:52 PM
NWBronco's Avatar
NWBronco
Pretty much, unless you are lucky enough to destroy the chain. Which is highly unlikely before the planetary, oiler, and fork go. Only way to see is to bust it open. By the time you have it opened up and the chain out, you are about 2/3 done with a re-build. That's why it's been said to find a t-case in a yard.
Old May 23, 2011 | 10:05 AM
Kemicalburns's Avatar
Kemicalburns
the 1356 is a strong tcase. it has issues when the fluid isnt kept up or if someone has put it into 4wd on dry pavement. this will cause the case to bind up and potentially fail. hard to say which happend here though.
Old May 23, 2011 | 10:11 AM
NWBronco's Avatar
NWBronco
They have been known to lose the chain oiler. And for said oiler to end up chewing the case at it mounting location. That's about it. Other than that, they are quite sturdy.
I'm with you. Web diagnosis only goes so far. He needs to open up the case.
Old May 29, 2011 | 12:15 AM
250sampson's Avatar
250sampson
yea im gonna open it soon, hopefully i see some metal shavings or something to let me know that the Tcase is the problem, im buyin it next week for 400, gonna be a good fixer upper
Old Jun 1, 2011 | 11:03 PM
FourXFord2's Avatar
FourXFord2
Hey, post some pics of the carnage you find! I lost the oiler, shift fork and 2hi and 4 hi in my t-case when it broke, never had one apart before but took me 30 mins to fix myself.
Old Jun 2, 2011 | 11:33 PM
250sampson's Avatar
250sampson
im not sure if im gonna pop it open yet, i just bought the truck today and i m stoked to start to fix her up, but how do i know if the oiler blew? cus that may be the issue im havin. dont wanna get a new case and have that one blow too.
Old Jun 2, 2011 | 11:40 PM
250sampson's Avatar
250sampson
after i put the new case in ill make sure to pop the old one open and post some pics for you
Old Jun 3, 2011 | 10:42 AM
toolman's Avatar
toolman
Having just torn one down, twice, I have a few thoughts. First, I don't think the transfer case has enough mass to make the whole truck shake violently. I would take a serious look at the U-Joints, flange bolts, and transmission/motor mounts first. Secondly, when it comes time to drop it, it's fairly simple. I would suggest pulling the seats and rolling back the floor covering though; You may find it easier to access the upper bolts. When disconecting the TC shift linkage, be careful not to reef too hard on the linkage at the case. If you damage the shaft that the shift plate rides on, you could find yourself stuck in one range or another because the shift plate can move allowing the shift forks to disengage from the plate. There's an excellent write up over on Pirate 4x4 with quite a few pictures ( COMPLETE BW 1356 teardown pics - Pirate4x4.Com Bulletin Board ) This particular bookmark goes to a post mid way down the page, so you'll have to scroll back to the top on your own...Sorry....
Anyhow, just my .02 cents !
-Scott
Old Jun 12, 2011 | 08:19 PM
250sampson's Avatar
250sampson
thanks alot man, im gonna try and switch the main ouput shafts from the 1990 to the 1989 case, thats gonna help me alot, i just cant find a socket that will fit in the half U joint yoke on the 89, i tried with the same socket i used on the 90 to get the plate yoke off and it got stuck in the yoke.
hjartland
Feb 7, 2017 12:30 PM
Gary Lewis
123
Dec 4, 2016 08:10 AM
250sampson
18
Jun 9, 2011 07:18 PM
rebelford
Nov 20, 2005 07:10 AM
adelyser
Jan 23, 2004 11:23 PM
