Having problems with my battery idiot light. I took both batteries out of the truck and had them tested. Both show good charge. Cleaned all battey posts and terminals. The truck is starting fine now but the idiot light keeps coming on while I'm driving. I don't know if this has anything to do with it, but the air conditioner doesn't seem to blow cold air now.
Please forward some ideas to me.
KB
The idiot light in my truck is hooked up to the alternator and has no other connection to the batteries.
Meaning it monitors alternator and alternator only. Most likely you have failing board or brushes on your alternator.
If you have luck similar to mine, the alternator will pass the bench test with flying colors.
I had strange symptoms when charging light was coming on at high rpm, but would go off when I up-shifted to lower rpm. Took about 10,000 miles for the alternator to definitely give up.
