air injection rail
air injection rail
the air injection rail on my 92 300 is cracked in a few spots and needs replacing. my mechanic told me it would be 4 hours of work for him to do it. i looked at it and im pretty sure i can do it myself. it looks like you just have to take off the top of the intake plenum and the throttle body. is there anything else im missing? do those weird studs that screw into the head just screw out? of course it looks straight forward, but it will probably end up taking me all day like everything else
also- would a badly cracked air injection rail make noise? my truck sounds like it has an exhaust manifold leak, but my exhaust manis are new, as well as the intake/exhaust gasket. this cracked rail really seems like the only thing left that could make noise.
I've taken the rail off a couple times from engines in the junk yard while I'm digging for EFI exhaust manifolds. It seems really straight forward and easy (never put one back on). I can get to the exhaust manifolds themselves in about an hour or less, I can't imagine it taking 4 hours to replace the A.I.R.
And yeah, I've heard they can make some pretty good noise when they get holes in them.
my two cents.... upper plenum comes off. once you take all of the stuff that you need to to do that, you will have enough room to do what you need to do to take the air tube off. on my engine swap that i did this past winter it took a line wrench to get enough grip to spin them loose. a regular combination wrench just rounded the flats off. the hex heads unscrew and spin around the tubes going down into the head. yes its as straight forward as it seems. any brackets can be taken off as you need to. no need to really worry about much. pb blaster and taking your time goes a long way.
and yes that air tube leaking can make alot of noise. i have the air tube to my cats disconnected and hanging loose. once it switches to that hose from the head its audible standing out side of the truck.
I may end up doing that...And red loctiting some small bolts and threading them in....To tidy things up
No problems....And I already had a new belt to eliminate the smog pump...
No
IDK
Yea
Sorry to be vague...But I simply did the swap at a Car-Quest....Undid the belt from around the SMOG pump, and pulled the belt taut again....took it in that way, and matched it...No issues since...
Also, idk why, but my dad keeps screaming that I am turning the water pump BACKWARDS, yet if you look at the belt routing, the belt turns the WP left to right with EVERYTHING attached....And with the SMOG pump/ A/C Compressor undone, it turns right to left...W-T-F...
2 trucks did like this and no overheating issues whatsoever...As I just said, I just acted as if i were deleting the A/C, when in all honesty, I was delteing the SMOG pump...same diff....Just measure how I specified...No probs then....I'll check for a part # today....
IDK
Yea
