what's your biggest goof during repairs
#31
Wow. Dumb things done while wrenching...... A few that come to mind right off....
1- Doing an HPOP install on a buddy's truck, underestimated the pressure of cold oil out the top of the HPOP reservoir fill plug, needless to say when we started it, i had an oil volcano that quickly puked out over a quart before we could shut it down....
2- Was changing the oil on my 6oh back in '09, changed the filter first(which as you know, is on the top of the motor) got distracted, and then started adding the new synthetic oil. I got 12 quarts in before i realized i hadnt ever drained the old oil out!
3- I had just done an excruciatingly tedious head gasket replacement on a toyota echo, and as i was testdriving it, i noticed an odd rattle coming from the timing chain cover area.... And as i was sitting at a red light pondering if i wanted to remove the valve cover to check it, it grenaded, ruining the head. Seems in my delirium late the night before, as i rushed to finish the project, i had finger tightened the exhaust cam pulley bolt, but never torqued it.... 15 years of timing and cyl head jobs, and all it takes is one key forgotten bolt. Those are the worst ones to do over....
I could keep going, but i dont want all of you to feel TOO good about yourselves.
#32
I once shot myself in the eye with carb cleaner while working on a snowmobile. That hurt.
When I did ball joints on my SD I put the brake dust shield on backwards. Oops.
Put a throttle slide plate in upside down in a dirt bike carb once, took me a while to figure out why it ran so bad.
I've accidentally punched myself in the face/nose/eye/lip/whatever more times than I can count thanks to wrenches slipping.
I have a few scars from my mechanic "skills."
I'm sure I could think of more if I really tried
#33
on
Yeah, I've whacked my face and head so many times. Whenever I quit cussing myself at the moment, I usually start to laugh...because it reminds of being a kid when you'd grab someone's arm (or they grabbed yours) and then slap them silly in their own face with it and say "Why are you hitting yourself, huh, why are you hitting yourself???" I feel like the idiot hitting myself when my hand or tool slips.
#34
#35
after doing atleast 3 hpop installs on other members trucks i installed a Termmy modded 17* pump on my truck
while putting everything back together decided to put a resistor in the ebpv plug
well after an hour of the truck running till it got warmed up and driving myself nuts
with help from Joey and Clay we figured out that the plug with the resistor in it was the ipr not the ebpv
needless to say it wasnt even throwing a code to help us lead us in the right direction because of the resistor ...
#36
#37
Rear end gears on the F350 were making noise so I decided I would fix it. Everything went well with installing and setting up the new gears. Reinstalled the rear end under the truck and filled it with oil. The jackstands were not level and the passenger side was somewhat lower than the drivers side and I didn't pay it any mind. Went on a test drive on a road with a lot of crown and again because of the crown the drivers side of the rear end was higher than the passenger side.
After about three miles I heard some noises. Tried to limp it home and didn't quite make it. Had to be towed the last 1/2 mile. Removed the drivers side wheel and saw that I had burned the end of the axle tube off.
This cost me a couple of grand. I guess oil never got to that side to lube the bearings.
#38
#40
I never understood why my Grandpa made me coat the bearings with oil when doing an inner axle seal, I always figured the diff would lube it like it was designed to....now I know why.
I have an f-350 and the clutch will not disengage unless the vehicle is turned off. Is it my master?
Sarge2
1999 to 2016 Super Duty
01-10-2012 09:43 AM
jrfletcher@ptmc.net
07-09-2003 11:41 AM
