An interesting problem
Old May 17, 2011 | 04:39 PM
bashby's Avatar
bashby
I dont know if it will help, but I'd put the timing back where it was, or better yet, set it with a timing light to spec.
Old May 17, 2011 | 04:51 PM
302flareside1992's Avatar
302flareside1992
Yeah im assuming the milage is crap but I don't ever bother to check the mileage because I don't wanna know how bad it really is
Old May 17, 2011 | 05:11 PM
slamed150's Avatar
slamed150
if you were closer i would just plug in the snap on scanner in and have a look.
Old May 17, 2011 | 05:26 PM
302flareside1992
An obd1 code reader
Old May 17, 2011 | 06:09 PM
slamed150's Avatar
slamed150
no a scanner. i can actually look at the data. not just pull codes
Old May 17, 2011 | 06:13 PM
slamed150's Avatar
slamed150
where u at
Old May 17, 2011 | 09:41 PM
Encho's Avatar
Encho
The Southernmost Mod
You messed up the iddle by moving that screw, the trouble comes back because the computer is compensating, so it gets back to where it was (there is a whole procedure to set the idle screw back to its place). You do have most probably a failing sensor.
Old May 18, 2011 | 12:09 PM
jimbo285's Avatar
jimbo285
I feel your pain. I have had several related problems (You can search my threads) Started out as low idle problem and would die when coasting or stopping at red lights. Morphed into lurching when shifting into reverse or drive. I went through the entire vacuum line system and fixed a few small leaks. i replaced IAC bypass valve. Each time i thought i was going in the right direction, the problem redefined and had to go different direction. Luckily i have 2 vehicles so i could put "known good" parts on it to troubleshhoot. Good luck and listen to whatsome of these people say here. They know!
Old May 26, 2011 | 07:50 PM
302flareside1992
I stay in Alexandria during the week and fredericksburg during the weekends
I set the idle screw like it was supposed to be when the engine was rebuilt and I haven't touched it since then and that was over a year ago and the problem just now started so the idle screw isn't gonna be it, unless it backed out on me which I doubt
john510
Apr 26, 2019 02:20 AM
caindog110
Feb 12, 2013 05:15 PM
truckrider814
Aug 3, 2011 12:33 PM
sealboy84
30
Jul 10, 2010 10:01 AM
paddler
Apr 11, 2009 08:44 PM
