Stereo System
Old Aug 21, 2011 | 08:36 AM
Stevem4134's Avatar
Stevem4134
Does the 2011 f-250 lariat crew cab come with a sub woofer.
Old Aug 21, 2011 | 01:14 PM
2000silverbullet's Avatar
2000silverbullet
Yep, the subwoofer is standard on the Lariat and KR, but you can get different head units that go with it. These are your 2 choices (from the order guide):
Premium AM/FM stereo w/digital clock, Single-CD/MP3
player, 8-speakers & subwoofer standard on Lariat
Navigation System with Premium Sound System AM/FM
HD stereo Single-CD player with MP3 capability, USB
port, In-dash touch-screen, Voice-Activated controls,
SIRIUS® Travel Link™ capability, digital clock and 8-
speakers with subwoofer.
Old Aug 21, 2011 | 06:19 PM
Stevem4134's Avatar
Stevem4134
Thank you for your quick and knowledgeable answer
Old Aug 23, 2011 | 08:27 AM
TheKid1's Avatar
TheKid1
Where the heck is the subwoofer?
Old Aug 23, 2011 | 08:37 AM
ruschejj's Avatar
ruschejj
If you have it, it's behind the rear passenger seat on the floor in a crew cab. I assume a similar location in a super cab or reg cab. It's a black plastic odd shaped thing. I would say that you could just turn up the music and locate it with your ears but the output of the factory sub is comical.
Old Aug 23, 2011 | 10:29 AM
TheKid1's Avatar
TheKid1
I have a 2011 Lariat and there is no subwoofer, just a plastic tray below the rear seats
WTF?
Old Aug 23, 2011 | 11:51 AM
2000silverbullet
WTF?
It's behind the rear seat, you don't have anything there?
Old Aug 23, 2011 | 01:08 PM
dbc001's Avatar
dbc001
On a technical point only; the physical separation of the tweeter and mid on the front and rear doors does not lend itself to the best sound stage. Yes, one can get esoteric and insert delay etc., however, for the better sound stage it is best to keep them very close together. I replaced the fronts with Infinity Kappa duals and disconnected the tweeters in the A Columns. I now run only with the fronts on, (fader full to front) and it is a huge difference. Better tonally and more life like.
Old Aug 23, 2011 | 04:30 PM
srkr's Avatar
srkr
Just upgraded all my spekers and amps.
Went with the 6x9 Infinities 4 of them.
Replaced all 4 tweeters.
Also had the Subwoofer replaced with a kicker 8" CVT
The Two Amps I had installed were a JBL for the 4 6x9's
The Subwoofer Amp is a Orion XTR 2504.
Sounds Pretty Good.
Shane
Old Aug 28, 2011 | 11:14 PM
urzu007's Avatar
urzu007
I am looking at upgrading the sub on a small budget but am a little confused with the factory sub. Why does it have 4 wires attached to the speaker? With that I am guessing I can not use the factory amp. I purchased a 6.5" Kicker 10CVT654 that was on sale for $50 thinking I could just swap the sub and have better bass. Any ideas on how to use the factory amp or what is a decent cheaper amp?
Old Aug 29, 2011 | 05:22 AM
2000silverbullet
The four wires going in are as follows (you'd only need the +/- for an aftermarket setup):
Subwoofer + Violet/Green stripe
Subwoofer - Green/White stripe
Body Control Module BU (Burgundy?)/ Red stripe
Enable/Clip detect Violet/Red stripe
Old Aug 29, 2011 | 09:55 PM
urzu007's Avatar
urzu007
Thanks that helps the confusion. Wonder why they did it that way.
Old Aug 30, 2011 | 05:18 AM
  #28
2000silverbullet
As you turn up the sound, you can tell the sub volume decreases, which is Fords way of saving the stereo so to speak.
It's pathetic in my opinion. Even getting a bigger amp to the factory door speakers (which is currently how mine is) makes a big difference. Adding the sub was just a bonus, but it would've been interesting to see how the factory sub performs with a "real" amp.
Old Aug 31, 2011 | 01:57 AM
  #29
btm991's Avatar
btm991
Here's my only complaint with this sound system...anytime I listen to music with my phone plugged in through the USB port I get a crackling or clicking sound through the two tweeters on the a pillar. I just had them replaced and it's still happening but only with my phone plugged in through the USB not with anything else. Anyone have any ideas on what's goin on??
Old Aug 31, 2011 | 12:00 PM
  #30
GR8Dane's Avatar
GR8Dane
Sounds to me like the tweeters aren't handling the sound. The compressed music coming via USB already struggles through those stock speakers and I noticed tons of static when I turned the volume up at all. The tweeters just turned to mush. Not sure if that is your problem but I'm pretty sure it was mine. I'm headed to pick up my truck in an hour where it has been getting all of the speakers and amps replaced in hopes to resolve that issue. I'll let you know how it turns out.
