1978 - 1996 Big Bronco
Ignition/starting problem
Old Mar 23, 2003 | 01:59 PM
RomeoAlphaYankee's Avatar
RomeoAlphaYankee
Question Ignition/starting problem
Good numbers to all my fellow FTE's. Here we go.
I own a 1981 Big Bronco with the 351M engine. It is very simple which means no AC, PW's or PDL's. Get the picture?
A few weeks ago I was unable to start the motor. Well, actually it fires when the key is turned all the way forward to the start position, however when I release the key, the motor shuts down.
If I could keep the key forward, the motor would continue to run, however that is not possible for obvious reasons.
Any helpful hints or websites I can visit pertaining to this problem is greatly appreciated.
Old Mar 23, 2003 | 02:57 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Ray, the trouble is in either the ignition switch or the resistor wire under the dash. My guess is it's a faulty switch.
Old Mar 23, 2003 | 10:43 PM
Chrisvte's Avatar
Chrisvte
I agree. I would definitely replace that switch. That is the most likely cause of your problem.
Phil
Jan 15, 2023 09:37 PM
moneyman136
15
Jan 11, 2015 04:16 PM
ethanberens
Feb 23, 2014 06:10 PM
jfralph
Oct 15, 2013 07:50 PM
MrBSS
Modular V8 (4.6L, 5.4L)
Jul 2, 2003 12:04 PM
