Starter Whine/Grind
Old Jul 1, 2003 | 11:26 AM
MrBSS's Avatar
MrBSS
Starter Whine/Grind
I have a 2001 F 150 w/ 4.6. Occasionally (3 times in last 2 months) it will grind and whine when I turn the key to start it. Apparently the starter motor doesn't engage the flywheel.
I thought maybe I hadn't turned the key firmly so will pay more attention in the future, but does anybody think I may be developing a problem or do they "all do that"?
Old Jul 1, 2003 | 05:08 PM
LxMan1's Avatar
LxMan1
Starter Whine/Grind
Either a bad spot on the flywheel or the start is failing to kick the bendix out far enough.
Jimmy
Old Jul 2, 2003 | 09:26 AM
MrBSS's Avatar
MrBSS
Starter Whine/Grind
If it's a bad spot on the flywheel, do we think it can "wear in" or is it only going to get worse? How would that happen, or is it likely a flaw in manufacturing?
Thanks!
Old Jul 2, 2003 | 11:33 AM
LxMan1's Avatar
LxMan1
Starter Whine/Grind
It would only get worse and eventually eat the teeth off of the starter. Another possibility, the starter could be loose, making it not mesh properly with the flywheel.
Old Jul 2, 2003 | 12:04 PM
MrBSS's Avatar
MrBSS
Starter Whine/Grind
Thanks; that I can check.
96halfton
May 28, 2018 01:38 PM
williej70
Jan 16, 2017 09:06 AM
kwc27
Large Truck
Oct 31, 2016 05:26 PM
mike L
Dec 25, 2013 04:16 PM
pinkpantherbeekeeper
Jun 12, 2013 07:32 PM
