Turbo casting flaw
Old May 14, 2011 | 11:12 AM
kereams's Avatar
kereams
Turbo casting flaw
Just a heads up to a warranty issue I had repaired this week. I had an oil leak on the truck that appeared to be coming from one of the oil pans or the rear main seal. The oil would collect on the oil pan and on the oil filter. You could visibly see it coming down both sides of the transmission bell housing. Even with dye in the oil it was very hard for them to tell exactly where it was coming from due to the incredible tightness of the engine bay. They ended up pulling the transmission out to get better access and to inspect the rear main seal. After getting better access they found a bad casting in the turbo that prohibited a proper seal on one of the plugs. There is a rather large tunnel looking channel on top of the motor without a drain, a good half quart of oil can pool up there before dripping down onto the bell housing. If I was Ford I would look at a way to drain that, could be quite the fires hazard. My truck build date is mid September 2010.
Thats it, hope it helps someone else... The truck is all fixed, oil leak free and drives great. The new TSB sure helps the shifting! Love my truck.
BTW - My dealer provided awesome customer service. I even sat down and had a long discussion on the motor with their lead Diesel mechanic who went to school on the 6.7L. Kudos to Dick's Mackenzie Ford in Hillsboro Oregon.
Old May 14, 2011 | 01:31 PM
maistroyoda's Avatar
maistroyoda
What is the mileage when this happened and how long have you owned it?
Old May 14, 2011 | 10:44 PM
kereams's Avatar
kereams
First saw oil around 5k miles. Had it since new.
Old May 15, 2011 | 08:09 AM
dschuffert's Avatar
dschuffert
That is great to hear you had a great experience with your dealer. Quite too often we only hear about the bad experiences. I am fortunate in my area that I know of two great service departments in two different dealers.
Nitro901
Jan 6, 2017 11:35 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 6, 2015 01:51 AM
FordF350Baby
Apr 19, 2008 07:47 AM
keithw99
Jul 13, 2006 02:38 PM
heybrent
1978 - 1996 Big Bronco
Aug 17, 2003 02:31 AM
