starter? HELP ASAP!!
Old May 13, 2011 | 10:34 PM
Atwiss's Avatar
Atwiss
Exclamation starter? HELP ASAP!!
today i was was doing alittle off roading and now the starter wont engage and i tapped on it a couple times and it starts but after that happens it runs like crap but only when im accelerating in gear but when i keep at a constant speed it doesnt do anything or when it idles? is it the starter?
Old May 13, 2011 | 10:57 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Starter has nothing to do with anything while the engine is running.
Josh
Old May 13, 2011 | 11:03 PM
Atwiss's Avatar
Atwiss
what could be wrong with the engine so im guessing the starter is bad and what else im just guessing here but not sure either a low compression cylinder, bent/bad valve or the starter isnt disengaging once it engages when i tap on it but not sure
Old May 14, 2011 | 12:50 AM
VocaTexas's Avatar
VocaTexas
Water in the distributor cap? Take the cap off and dry it out.
Old May 14, 2011 | 09:58 AM
Atwiss's Avatar
Atwiss
i will try that than but need to find a starter first lol and work at 2
Old May 14, 2011 | 12:13 PM
Atwiss's Avatar
Atwiss
i got it to start so starter is fixed
Dr. Johnson
Oct 21, 2018 07:19 PM
Mab1957
Oct 21, 2015 01:25 PM
oneborn2fly
Nov 17, 2014 06:58 AM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
Chris_ce
Jun 12, 2005 02:03 PM
