emergency brake help
Old May 13, 2011 | 08:02 PM
bergy 2000's Avatar
bergy 2000
My 2000 ex emergency brake pedals almost goes to the floor. It does hold but it could be a lot tighter. Is there a way to adjust it or do I need a new cable? Does the emergency brake use the primary pads also or do they have their own? Please help....Thanks
Old May 13, 2011 | 08:12 PM
cbradford's Avatar
cbradford
The ebrake uses drum brakes in the center of the rear rotors and can be adjusted by removing the plug on backing plate then using a brake adjusting tool.
Old May 13, 2011 | 08:26 PM
bergy 2000's Avatar
bergy 2000
do I need to pull the wheel? Where is this located exactly.
Old May 13, 2011 | 08:39 PM
cbradford's Avatar
cbradford
No need to pull the wheel unless you want to pull the drum and inspect the shoes.
There is a slot on the inside of the backing plate and it usually has a rubber plug.
Old May 13, 2011 | 10:38 PM
Karlsgems's Avatar
Karlsgems
Hey, while we're on the topic of Parking Brakes.....I have the opposite problem! Mine is so tight that I can hardly apply it. Maybe goes down a couple (2-3) inches....is this okay??
I am assuming that this will loosen up over time, but just wanted to run it by you guys and see what you think.
Thanks in advance!
K.
Old May 13, 2011 | 10:40 PM
jrings's Avatar
jrings
I just adjusted mine last weekend. The brake worked just like yours but not very well... I took out the little plug behind the rotor and tried to adjust the little star nut with a brake adjusting tool but it was such a PIA I did end up taking off the caliper / brakes and rotor to be able to inspect the condition of the e-brake shoes and adjust them while being able to see what I was doing. I am glad I did because it was a much smoother process and I was able to double check the rear brake job I had done a couple of months prior...
E-brake works great now!
Old May 13, 2011 | 10:47 PM
jh818's Avatar
jh818
There's an oval rubber plug on the back plate of the wheel. You can use a flathead screwdriver to adjust the star wheel behind the oval opening.
Old May 13, 2011 | 11:21 PM
wpnaes's Avatar
wpnaes
Thanks in advance!
K.
I think that's fine as long as the brakes hold you on a slope in Neutral. I too had a very loose e-brake and adjusted the star nut until I had your 2-3 inches of travel. - I agree with Jrings, it's easier with the rotor off so you can see what yer doin' and try some test fits to make sure the pedal is where you want it (both brake sides of course). A few pics will make this easier to understand.
Old May 13, 2011 | 11:41 PM
Karlsgems's Avatar
Karlsgems
WPNAES--
thanks for the input! Yes, the brake does hold on slopes. I live in a hilly area and have had no problem at all. Just REALLY hard to apply the brake!
Those pictures were great, by the way!
Sincerely,
Karl.<!-- / message --><!-- attachments -->
GTO-Ron
20
Sep 13, 2015 04:28 PM
HILLBILLY BOB
Aug 21, 2015 02:37 PM
Eddillard79
Oct 9, 2014 07:15 PM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
vinniez
Jun 1, 2004 10:00 AM
