PInion angle shim
Old May 13, 2011 | 12:23 AM
rschwab's Avatar
rschwab
PInion angle shim
Hello All,
I am in the process of lowering my 67. I will be doing the half axle flip.I ordered the 6 deg shims that were recommended on this site. I received them and they have a slight radius on one side.
Is this correct?
I thought they would be flat on each side
any help is appreciated
Old May 13, 2011 | 05:42 AM
Talltruck's Avatar
Talltruck
What you have to pay attention to is making sure the degrees of angle are the same on the trans as they are on the rear end. So put a degree wheel on the face of the trans output and if it measures say 5 degrees then you want to make the angle of the pinion as close to 5 degrees as possible. This is called keeping the u joints in phase.
Old May 13, 2011 | 10:45 AM
rschwab's Avatar
rschwab
Thanks,
But the shims I have have a radius on one side of the block. It seems to me it would not work good because it looks like it would allow the axle to be able to rotate slightly. I thought that the angled sides would be flat not radiused
Old May 16, 2011 | 04:53 AM
Talltruck's Avatar
Talltruck
A SLIGHT radius on one side is to match the curvature of the leaf spring.
pilgrimbizket
22
Feb 17, 2015 09:26 AM
lilrobo
May 3, 2014 08:32 PM
straight-shot
Mar 4, 2014 10:27 PM
wtroger
Feb 28, 2011 08:28 PM
