CB Install
Old May 27, 2011 | 01:47 PM
  #31
robroy90's Avatar
robroy90
Still looking here
I haven't decided what kind of radio yet, but I have been evaluating antenna mounting locations and found this:
main
Never even thought of using stake pocket to mount. Pretty trick!
I would still like to find an elegant method to replace the factory AM/FM with a suitable antenna because the AM/FM is useless to me.
-Rob
Old May 27, 2011 | 10:22 PM
  #32
jxcasey's Avatar
jxcasey
CB Install
The CB I have will slip into the storage slot on the driver's side of the console (It would also fit into the storage slot on the passenger side of the console.)
To prevent the CB from scratching the plastic of the console, I used a rubber-like, non-slip shelf product more often used in rvs under plates, etc. in cabinets so the plates don't slide around.
The rubber-like material should create a protective shield between the CB--on either side and the bottom where it touches--and the console. I would prefer not to damage the side surface of the console.
I think and hope this simple solution will work. Sorry I don't have a picture.
Old May 28, 2011 | 06:18 AM
  #33
roadkingfl's Avatar
roadkingfl
I did the same thing, it does work......
Old May 28, 2011 | 08:33 AM
  #34
porthole's Avatar
porthole
Many many moons ago Dodge had a factory optioned AM/FM cassette with a built in CB. The radio used an adapter between the regular antenna and the radio. This allowed the CB to work with the factory antenna. Was pretty cool for the day.
Eventually put one in my 1978 W100 Power Wagon, my first pick up
Old May 28, 2011 | 09:56 AM
  #35
lakedweller's Avatar
lakedweller
I had an all in one in my 1980 Olds Delta 88. Still have the radio somewhere in my barn....
Old May 29, 2011 | 10:37 AM
  #36
Davgt500's Avatar
Davgt500
Originally Posted by porthole
Is the K-40 still the top dog with antennas?
I'm not sure, but I've always used the Firestiks and had good luck with em.
Old May 29, 2011 | 10:52 AM
  #37
Davgt500's Avatar
Davgt500
main
-Rob
I am going to go with Firestik's stake hole antenna mount, A very clean and easy hook-up, or so it appears.
http://www.firestik.com/Catalog/SS-294A.htm
cameeks
Texas Chapter
Dec 8, 2013 09:37 AM
cameeks
Jul 30, 2013 08:26 PM
kawakibi
6.7L Power Stroke Diesel
Mar 13, 2013 03:10 AM
Nov 7, 2009 01:03 PM
