I picked up a shroud that is a perfect fit on my original Radiator. Stamping on radiator is C6TA-theres a couple of numbers but a small plate with AC is over them. Rest of stamping on radiator is P MO 66
The shroud mounting area measures 28 3/8's" X 20 1/4"
Upper radiator hose measures from outer edge 22" lower hose measures 6 1/4"
The shroud is a C8TA 8146 S other stamping on shroud FORD ROTUNDA
BARNO BROS. FIRRE CO
The shroud lines up perfectly. The mounting surface is even all the way around. Perfect line up with upper and lower hoses.
I do not know if the center area for fan is lined up.
I have just put in a brand new radiator and the hoses don't match original radiator but are close. So I will have to have a custom shroud made.
Just letting you guy's know that this shroud lines up for the 64 with a 292 in it. I don't have A/C
Someone may jump in and let us all know if it will work or not. It is a perfect fit for the radiator.
I don't know how this post wound up here, Please forgive me
Reason: posted in the wrong area
I picked up a shroud that is a perfect fit on my original Radiator. Stamping on radiator is C6TA-theres a couple of numbers but a small plate with AC is over them. Rest of stamping on radiator is P MO 66The shroud mounting area measures 28 3/8's" X 20 1/4" Upper radiator hose measures from outer edge 22" lower hose measures 6 1/4"
The shroud is markedC8TA-8146-Son the upper drivers side corner.
The shroud lines up perfectly. The mounting surface is even all the way around. Perfect line up with upper and lower hoses. I do not know if the center area for fan is lined up.I have just put in a brand new radiator and the hoses don't match original radiator but are close. So I will have to have a custom shroud made.Just letting you guy's know that this shroud lines up for the 64 with a 292 in it. I don't have A/C
ID number: C8TA-8146-S = Ford part number: C8TZ-8146-K replaced (2/1973) by D3TZ-8146-C (marked D3TA-8146-DA or D3TA-DA).
Original applications: 1967 F100/250 352 / 1968/76 F100/250 360/390 / 1967/76: Without the Super Cooling Radiator (std equipment F350).
This shroud is a bolt in mod for 1965/66 F100/350's. I've been recommending it for over 4 years, but the problem is...Ford just obsoleted it.
One member bought one, installed it in his 1964 F100 292, said it fit perfectly.
