Tan drivers door panel and an air breather snorkel for a 83 460 cu. in. I have seen the LMC panels and will probably go that way. My local Ford dealer says the snorkel is obsolete.
What part are you calling "snorkel?" Is this the duct & valve that attaches to the air cleaner?
Or is it the flexible fresh air tube that attaches to the duct, then to the radiator support?
Thanks for the replies. It is the second piece,the one that goes to the rad support I would like to change . I would like a really good one ,if not even NOS . I plan to enter this truck in the Stock class at the National weekend here in Ontario Canada this coming August. I am going to clean the original and hope to make it look better if I can;t find a clean replacement.
E3TZ-9A624-D .. Fresh Air Tube-Duct to Radiator Support / Obsolete
