Cab mount frame support question
Old May 11, 2011 | 08:11 PM
77FordDW's Avatar
77FordDW
Here's a picture of mine (sorry for it being upside down, I'm currently working on the frame and didn't want to flip it over just for the picture, haha):
Does anyone know what the ID of that hole is supposed to be? I'm either going to repair that one or simply build new ones, but I'm not quite sure what that hole should be.
Also, this may be asking a bit much but what about the length, center to center across the frame, from one to the other?
I'm sure the holes are big enough to allow all the movement the cab would need to compensate any abnormalities, but I wanna get it kinda close. I don't want to buy frame savers or new mounts from JBG simply because I weld for a living and all these materials are free to me. :-)
Thanks!
Old May 11, 2011 | 08:16 PM
73f250highboy's Avatar
73f250highboy
thats badd haha i think the mount should snugly fit in there (i cant remember) but if you have the old rubber mount maybe? someone else on here probably knows but my spare frame/parts are not at the house im at so i cant measure them for you till the weekend
Old May 11, 2011 | 08:25 PM
77FordDW's Avatar
77FordDW
When I get done it'll be one solid piece and you wouldn't know it was previously rotted, haha. I just need to know the ID of the hole so I get it right. :-)
The old mounts are mutilated, but I'm almost 100% sure the hole is bigger than the mount/bolt that go down through it.
Old May 11, 2011 | 08:37 PM
73f250highboy
i will try to get measurements for u this weekend if no one else chimes in before then
73f250highboy
i wont have the measurement from the frame tho because i believe those are different
Old May 11, 2011 | 08:41 PM
77FordDW's Avatar
77FordDW
It's fine. The hole size is most important.
Thanks!
Old May 12, 2011 | 12:58 AM
montana_highboy's Avatar
montana_highboy
Originally Posted by 77FordDW
Does anyone know what the ID of that hole is supposed to be? !
It's 1.75"
Old May 12, 2011 | 04:46 AM
77FordDW's Avatar
77FordDW
Ah, so all 4 on the cab are the same and the core support is a bit smaller. (1 3/8"-1 1/4") Thanks!
blick
Oct 6, 2014 12:06 PM
77FordDW
27
Feb 12, 2012 10:23 PM
jniolon
Jul 18, 2011 02:45 PM
ralphhood3
Feb 22, 2011 12:33 PM
77460f150
Jul 17, 2004 07:59 AM
