Sponsored by: Innova
General speaker placement questions
Old May 10, 2011 | 09:57 PM
wyckedcombo17's Avatar
wyckedcombo17
Evenin' yall.
I am looking to put an audio system in my '78. I have two 6x9's that I would like to install instead of door speakers. They are 3 way, and I was wondering if I put them behind the seat up against the corners of the cab in a little plywood frame/box thing, do you think that would be a good idea?
I'm wondering if it will sound muffled at all, with the sound having to go through the seat. Also, would having the speakers oriented towards the front or each other make a difference?
Thanks,
Dan
Old May 15, 2011 | 09:26 AM
lariat97's Avatar
lariat97
go to Parts Express.com. Get a set of Dayton 6.5s & a pair of Dayton tweeters & a pair of crossovers. Take your door panels off & see if you have a speaker cutout. If not make one at the bottom front of your door to fit the 6.5s. you will like these much better than the 6x9s you have. I think my 74 had 6x8 cutouts. I'll get the part numbers for you. For about $45 a side you can have a great sounding set of American made speakers
Old May 15, 2011 | 09:51 AM
lariat97's Avatar
lariat97
Here the model numbers
Dayton Audio DC160S-4 6-1/2" Classic Shielded Woofer 4 ohm $24.35 each
Dayton ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter $7.95 each
5 kHz High Pass 4 Ohm Crossover $5.95 each
Melmo65
Nov 14, 2012 06:28 PM
yendor0801
6.7L Power Stroke Diesel
Feb 23, 2012 05:18 PM
CWS15
Apr 7, 2004 04:20 PM
moose94
17
May 31, 2003 01:55 AM
