i was wandering if anyone knows where i can get a transfer case shifter lever for my truck the owner before cut mine down to the floor and i want the original one thanks
You need to be specific and list all the pertinent details when you ask a question like this.
What year is the truck? Does it have a A/T or a M/T? If a M/T, does it have the SR-OD 4 speed w/overdrive, or a 4 speed without overdrive? Does the shift lever have a "dogleg" in it, or not?
1980/86 F150/350 & Bronco: There are TEN different T/C shift levers, one type does not fit all.
I've already searched, have found a coupla different types available NOS, now all I need to know are the details.
it is a m\t without overdrive im sorry NumberDummy and its out of a 83
E2TZ-7210-B .. T/C Shift Lever / Obsolete
Use with 4 speed M/T w/o SR-OD: 1982 F150/350 & Bronco from production date 11/1981; 1983/86 F150/350 & Bronco.
Use with C6: Same applications as above / Use with AOD: 1982/85 F150 & Bronco from 11/1981 to 11/1984.
No Ford Dealer or obsolete parts vendor has any. But, when I checked earlier, one source-cannot recall exactly who (coulda been Green Sales Co.) had one, but now it's no longer listed.
