Backfiring
Old May 10, 2011 | 09:40 PM
Phy's Avatar
Phy
Originally Posted by PLC7.3
If an exhaust valve does not open engine will force combustion into the intake on next stroke... so I'm told.
Yeah it would. I've been trying to think of scenarios that would explain it, but I hadn't thought of that one.
Old Jun 19, 2011 | 05:51 PM
sams6.9's Avatar
sams6.9
sorry ive been busy and havent had time to play with this truck much, but here is a clip of what it does.
YouTube - ‪6.9‬‏
Old Jun 19, 2011 | 07:32 PM
bashby's Avatar
bashby
Hard to hear on my laptop, but is it only doing it on deceleration? I'd take the air cleaner off and listen. Might even see a fireworks show.
Old Jun 20, 2011 | 05:34 AM
sams6.9's Avatar
sams6.9
it does it worse if your driving it (most notibly taking off) on the other hand if it sits and idles for a min it quits doing it
Old Jan 11, 2012 | 01:52 PM
glowplugeaters's Avatar
glowplugeaters
my truck is doing the same tghing
Old Jan 11, 2012 | 04:27 PM
kenpobuck's Avatar
kenpobuck
Sticky valve maybe?
Old Jan 11, 2012 | 05:02 PM
eatont9999's Avatar
eatont9999
Yeah, that is definitely a valve issue. It may not be sticking open all the time, so the compression test could have come out just fine. Maybe the sticking happens at x RPMs only. I remember hearing somewhere that people have freed up a sticking valve by spraying WD-40 or some similar lubricant down the valve stem. Maybe I am thinking of something else entirely. It's one of those PITA problems because you have no real good way to find out what cylinder has the issue unless it is obvious when you take the valve covers off.
Old Jan 11, 2012 | 05:16 PM
glowplugeaters
I hope that it goes away it seems like it only happens the worst after iv driven the truck for a wial . I'm going to put some marvil mystery in the oil and run some transmition fluid through to see if it helps
Appledrews
Feb 23, 2016 08:38 PM
Nwynn24
27
Jan 22, 2016 06:40 PM
Psychowolff1
Jul 25, 2015 02:37 AM
redsquirrel_7
Bronco II
Oct 15, 2013 08:26 PM
wskline
Nov 16, 2009 08:54 AM
