oil temp
Old May 9, 2011 | 07:21 AM
offroadracer's Avatar
offroadracer
oil temp
What should the oil temp be at freeway speeds? Mine is 240 with 20psi. Is this normal? Oil pressure seems low. Thanks
Old May 10, 2011 | 07:36 AM
Freaksh0w's Avatar
Freaksh0w
What engine do you have? What RPM do you turn at freeway speeds? 240 seems a little high for light cruising, but I don't know for sure. Usually oil runs in the 180-210F range. 250-300 when hot rodding. But there are so many factors.
Old May 10, 2011 | 08:59 PM
offroadracer
oil temp
Sorry about the lack of info, late night. 1990 f 150 with 302 with aod.
I have aftermarket gauges. I know that I have very tall gearing, so the rpms are low. I can't even get into overdrive. I bought the truck used, so don't know the history of the motor. The oil pressure seems low to me.
Axemant31
Mar 1, 2007 07:29 AM
Pastmaster
Oil & Lubrication
Sep 26, 2002 11:07 PM
wmblanken
Jul 20, 2002 06:44 AM
dave thomas
Oct 1, 2001 11:07 AM
lvstang
Aug 23, 2000 09:48 PM
