300 six head question
Old May 8, 2011 | 09:49 PM
rentakid94's Avatar
rentakid94
hello, i have a 300 sitting in my shed all torn down. im getting ready to bore it and everything. but i was reading that you can shave the head down a little bit. i am currently majoring in the machinist field at school so i was wondering how much i could shave off the head. well what the maximum is that i can take off. i was thinking .015 thousandths. but im not sure if thats the maximum. the bottom of the head is rusty so thats why i want to shave it down and so i can up my compression.
Old May 8, 2011 | 09:57 PM
Harte3's Avatar
Harte3
Mill it only enough for clean-up and truing...same with the block and your compression ratio should still be good for the less expensive grade of gas.
Old May 8, 2011 | 10:05 PM
F-250 restorer's Avatar
F-250 restorer
Of course the exact way to do it is to measure the chambers and calculate the c.r. using one of the online sites. You can read up on the process. If you got to Clifford Performance and read about the build he markets, IIRC he says take .060" off the head. But with todays gas prices, no one wants to have to use premium.
However, I took .020 off the block, and the same off the head, and run the cheapest gas possible w/o problem of pinging ... until the outside temp hits about 110*, and then it pings like crazy, and I have to dump in a can of octane booster. You want to shoot for 9.0 to under 9.5:1 c.r.
go2guy
Apr 4, 2014 01:27 PM
JBradley500
Jan 28, 2007 10:58 AM
smoulding
20
Feb 4, 2006 12:57 AM
FordCardinal
Aug 15, 2004 03:31 PM
