2011 Ford Hitch Insert
Old Aug 1, 2011 | 04:31 PM
scraprat's Avatar
scraprat
Top Answer: 5
I just line the holes up before you push the insert in and stop when insert is flush with mount.
Old Aug 2, 2011 | 08:13 AM
Boomer23059's Avatar
Boomer23059
If only that worked. See previous posts.
Old Aug 2, 2011 | 06:06 PM
scraprat's Avatar
scraprat
Top Answer: 5
Before pushing the insert all the way just start it.
Then insert the hitch lining the holes up, grasp hitch behind insert resting thumb so that the insert and hitch don't move(holes), slide in, put pin in, done.
Or just weld it probably be easier for you.
Mine is the same as yours. Yes, at first it's was a pain now I just do what I typed. No problem.
White gold
Mar 2, 2017 11:22 PM
MarkyB98
All Things Towing
20
Oct 28, 2016 06:15 AM
golfmedik
6.7L Power Stroke Diesel
19
Jan 12, 2015 10:20 AM
Hd05
24
May 26, 2011 09:01 PM
Buzzard_Wing
Aug 12, 2009 06:29 PM
