Timing Gears
Old May 8, 2011 | 01:33 PM
RickinNH's Avatar
RickinNH
Timing Gears
The timing gears on my 95 4.9 300 are shot.
My question: Is this the type of engine where the valves and pistons can be damaged or am I safe in that area?
Thanks
Old May 8, 2011 | 01:55 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Not sure on that one, but DEFINANTLY be careful of the cams' thrust plate....they'll break if you aren't nice an easy....and CAREFUL...
Old May 8, 2011 | 06:34 PM
RickinNH's Avatar
RickinNH
I mean........I was driving and the engine stopped.
The Gears need replacing (Pushrods are not moving when the engine is cranked).
What happens to the Valves and Pistons in this case? Do they come together or is it the type of engine where it does not matter.
Thanks
Old May 8, 2011 | 07:50 PM
joshofalltrades's Avatar
joshofalltrades
this is a free-spinning engine, so there should be no damage to anything else. i would recomend upgrading to an all-metal gearset, and install new lifters while you have it all apart, maybe pushrods too.
i dealt with one of these in my flatbed awhile back, its a PITA to remove the camshaft with the engine in the truck, but can be done (details on request). and removing the cam is required in order to change the gear.
Old May 8, 2011 | 09:57 PM
F150xlt's Avatar
F150xlt
The 4.9 is a non-interference engine. No damage is done when the timing cam gear
teeth go bad.
I installed a Cloyes metal timing gear set and regret it. The whining noise is
terrible. I should have installed the factory type timing gear set that used a
fiber cam gear.
Old May 9, 2011 | 01:21 PM
joshofalltrades
that quiet whine is the nature of all-steel gears, and is the reason that ford chose a fiber gear, even though it doesn't last as long. they offer a set where the cam gear is aluminum, which is significantly quieter than steel but still much more durable than the fiber.
i'm happy with my all-metal gears, i noticed them at first, but honestly didn't even hear it when i drove that truck a couple days ago
MechaNick702
Apr 28, 2014 09:08 AM
daypray1
2004 - 2008 F150
May 20, 2008 05:51 PM
LxMan1
13
Aug 29, 2002 10:12 AM
Varnish
Jun 25, 2002 02:52 PM
Torky
Nov 20, 2001 04:17 PM
