frame work
Old May 8, 2011 | 03:21 AM
fordcaver91's Avatar
fordcaver91
frame work
Ok i got a 89 f150 ex-cab short bed. i was thinking about putting a long bed on it. To do so i have to lengthen the frame a little before the rear tires. How hard would it be to do this? It also has to be as strong or stronger than stock. What else is there to do? thanks.
Old May 8, 2011 | 07:09 AM
CWPottenger's Avatar
CWPottenger
It can be done. If you are doing that then Z-cut the frame, weld together and then fish plate the joint. If done right it will be stronger than original..
other option is go to a JY and pull a long bed frame. clean it up and then just transfer everything over to "new" frame.
thunderbirdcakes
Oct 30, 2013 08:55 AM
Canus
Mar 12, 2013 06:20 PM
randrford
Apr 10, 2008 11:34 AM
Stanstruck
Paint & Bodywork
Jun 28, 2004 03:48 PM
Acrasia
Feb 28, 2003 06:03 PM
