Another NO Start...........
Old May 8, 2011 | 12:31 PM
96ExtracabPSD's Avatar
96ExtracabPSD
12 volts won't shock you, can make things very hot very fast, but not shock you. I have used a crecsent wrench to jump across the two big terminals on the solinoid when it quit.
Old May 8, 2011 | 01:26 PM
84-6.9L's Avatar
84-6.9L
Ya, you don't need insulation except when you become the ground!
Old May 8, 2011 | 03:11 PM
dyoungen's Avatar
dyoungen
Here's the sequence I"m following, compliments of jas88.
1) Remove steering wheel.
2) Remove the turn signal lever.
3) Remove two-piece plastic column cover that hides column where it meets dash.
4) Drop column down and remove ignition switch. Put column back up but do not tighten bolts.
5) Remove ignition lock cylinder.
6) Remove lock cylinder gear (snap ring pliers required). It is down in the hole that you took the lock cylinder out of.
On number 4 "remove ignition switch", is it held to the steering colum by 2, 7/16 nuts and has the long rod from the steering wheel end of the colum to the underside of the switch where the bundle of wires are connected?
Old May 8, 2011 | 03:36 PM
dyoungen's Avatar
dyoungen
has anybody seen a parts breakdown of the steering column on this site or anywhere?
Old May 8, 2011 | 03:57 PM
84-6.9L's Avatar
84-6.9L
Never done one before but i took one out of a junkyard for a buddy (the column was already dropped). Id sure think you could leave the wheel on and just drop the column the switch is about halfway down the column itself far beyond the lock cylinder and turn switch. This was on an 84 but i don't think they changed that part.
Old May 8, 2011 | 08:11 PM
dyoungen's Avatar
dyoungen
I"d still have to remove the ignition switch which I think is part of the problem. It feels like metal scraping metal when I turn the key and gets real hard to turn the key toward the end of the turn. Just wish I had the fixed steering column instead of the tilt.
Old May 8, 2011 | 09:12 PM
84-6.9L's Avatar
84-6.9L
The grease in them gets dry most benefit from a good cleaning
Old May 9, 2011 | 02:33 PM
dyoungen's Avatar
dyoungen
96extracabpsd I was able to jump the selnoid and she started right up. Runs great, just doesn't work with the key. Nowe back out to remove the key switch. The starter switch, does it have around 10 or so wires connected to it and is bolted to the top of the column?
Old May 14, 2011 | 08:07 PM
eatont9999's Avatar
eatont9999
Pop the hood on your truck and put one had on the positive terminal of your battery and the other hand on the negative terminal. Tell us what happens...
I already know the answer.
magnumak1
15
Sep 12, 2014 03:50 PM
Houston Cowgirl
Mar 24, 2012 10:22 PM
Thunder Road
1997 - 2003 F150
Oct 27, 2009 07:01 PM
poooch
Dec 16, 2007 12:27 AM
pmoon
Oct 16, 2007 12:19 PM
