Sponsored by: Auxito
Ignition switch linkage broken..
Old Sep 29, 2009 | 08:52 PM
Thunder Road's Avatar
Thunder Road
Anyone had this to happen to them?
Turning the key doesn't do anything; removed the switch and when turning the key- the place when the switch prong goes does not move.
Appears to be a broken link - anyone have any R&R procedures?
Old Sep 30, 2009 | 08:20 PM
torkum's Avatar
torkum
Is the part showing in this pic?
Old Oct 1, 2009 | 09:43 AM
Thunder Road
No..it's INSIDE all of that cast aluminum...
Old Oct 27, 2009 | 04:08 PM
RobertAna's Avatar
RobertAna
My friend is having trouble with his 97 frod F-150 ignition switch. I think the linkage is broken that moves the stem on the electrical switch. Does anyone have any info on how hard it is to change this out or what to do?? I did pull the switch out and he can manually start his truck and drive it, but the dashboard under the steering wheel is hanging down.
Old Oct 27, 2009 | 07:01 PM
Thunder Road
It's a pain in the butt, Robert.
Basically, one has to remove everything below the speedometer and rearward of the knuckle in the steering shaft before it goes into the firewall.
The steering unit is best worked on at the bench and the hardest part is getting the tilt-spring back into place.
Mostly, it's just a matter of making sure you take good sequential pictures as you disassemble it- so it can go back together correctly.
If you have specific questions- ask away...
kelsbell
General Automotive Discussion
Aug 21, 2015 11:49 PM
Bill Berringer
May 5, 2015 07:56 AM
josiewales
Feb 14, 2015 09:58 PM
1994F2507.3L
Jan 21, 2015 04:17 PM
