7.3L Stock Intercooler
I just bought a 2000 F250 w/ 147k miles on the 7.3. The truck is super clean and the guy took great care of it. He did some mods, Banks exhaust, Trans Command, Pyro and Boost Gauge, Big Head Waste Gate and Ram Air. He also lifted it 6 inches and put 35's on her. Air bags in the rear for load leveling.
4 of the 8 injectors failed the buzz test, so i am now trying to educate myself on the options. The guy whi inpected it also said the turbo pedestal needs to be resealed and modified? What gives on the mod?
Here is my plan,
Replace the injectors with some performance model. say 100HP. Have no idea what brand or whos to use. Replace the stock turbo with a GT38. New Banks Ram Air, New CFM+ intake, New Banks Techni Cooler, New Bank Billet Torque Converter
How can I tell if the intercooler in this thing is stock or aftermarket?
Will I need to run a performance HPOP?
Will I need a performance fuel pump system?
Whos injectors and what size shoud I use?
Whos programming?
Crud!!! Im having a meltdown here....
I want a to use the truck to tow 6-8k pounds with 100% reliability, but still be able to put a smile on my face when I mash the throttle on the way to work!!!
To whomever answere my thread... THANK YOU ahead of time. I appreciate your time.
My first question is how did the injectors fail the buzz test? Codes or did they not buzz when the test was run? With 4 injectors supposedly not working, the engine should be jumping around so rough that it feels like it's trying to jump out from under the hood. Which 4 injectors? Are they all on the same side? Any other codes present? It could be a wiring issue.
As for the mods, I'd suggest you read here and figure out what your realistic HP goals are. If you buy a 100 hp chip or 100 hp injectors, you don't actually add 100 hp at the wheels. Usually not even close to that so try and get those numbers out of your head unless you decide that you want something like 400 rwhp. Then that can be a goal to shoot for.
I'd start by dealing with your 4 injectors first. If the truck seems to run fine, don't buy any injectors yet. If you do need injectors, don't get improved injectors on only 4. Do all 8. Jim at Rosewood diesel (a site sponsor) can build you a good set of injectors or get some Casserly built injectors. You can get them from sponsors like Riffraff diesel. Don't buy from pensacola diesel just because you found them on the internet and they have great prices. You'll regret it as soon as you get them installed and discover you've got to pull some back out.
You won't run out of fuel so don't worry about that, but there are some things you can do to improve the fuel weaknesses. The in tank mods and the FRX will help.
I'd wait on the HPOP until you get the mods installed so you can see what you've got.
For tuning, DP-Tuner is a site sponsor. Total Diesel Performance, & PHP are other popular ones with a few other honorable mentions coming on strong. They will run circles around the off the shelf stuff like Edge, superchips, banks, etc.
You're probably ok with the stock intercooler for now also, but installing a shift kit would be a wise idea. My suggestion would be to price up all the Banks stuff you are thinking about and get that number in your head. Then call Clay at Riffraff Diesel and let him suggest a package. You'll get a whole lot more mods and power for less money going with Clay.
The mechanic who looked at the truck for me (All Time Gas and Diesel, Glendora CA) told me that 2 of the 8 were shot and 2 more were showing signs of going.. no trouble codes though. Rough idle at time, a top end knock somewehere in the right bank, sometimes and HORRIBLE fuel mileage.. somwhere in the 7.5 - 8 MPG range.. no joke.
As far as the referal for the mods, Ill give Clay a call on Monday.. the feeling in my gut says my budget is around $10k on this thing. Im in the middle of balljoint and tie rod ends right now... moving on to power steering hoses, just replaced the belt tensioner and idler pulley... I figure Ill have $20-22 into her, but its a 7.3L, clean, paid for, and at least I know what I got!!!
Thanks!!
Any way you can post pictures for us to take a look at it? If you have a photobucket type account or upload them to your gallery here.
Edit: and as you can see, Clay is around most of the time anyway so you don't really have to wait until Monday to call him, but his prices will sound a whole lot better if you price the Banks stuff first.
Clay,
I just pulled up your website, I will definately be giving you a call.
Again guys, thanks for the help... Ill keep you posted as this progresses!!!
Come to think of it, this is another reason why I have gravitated towards Bank's products even though they cost a bit more.... 99% have C.A.R.B. certification. Soooo funny that you would post.... I had completely forgotten about this issue!!!
Does anyone know how to determine which mods are CA legal and which are not? I know if they carry a CARB number they are but any other general guidlines?
Other than do absolutley nothing at all because I happen to live in Leftest state in the Union.
Figures someone would come along and lick the red right off my lollipop!!
Thanks again....
