ERG Wires = squirels ate!!!
Old May 7, 2011 | 03:24 PM
christra's Avatar
christra
A squirel ate my ERG wires to the numb. I was able to pull the wires & splice new wires, BUT like a fool I forgot to write down what colors go to specific pins. It a 2004 6.0 d, so it has 5 wires. If someone can look at theirs & tell me what color go to what pin Facing the motor from left to right, I think the first is red, but that's I'll I can remember. Thanks
Old May 7, 2011 | 04:12 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Looking over the front end at EGR valve:
Red, Brown/red, blue/red, White/red
This is the best picture I could get of the EGR wires. I think that second wire from left was brown/red.
Old May 7, 2011 | 09:31 PM
christra's Avatar
christra
Thanks....That's great...I'll try it in the am
Old May 8, 2011 | 10:29 AM
christra's Avatar
christra
Mine is 5 wire, colors are red, gray/red, grn/org, brn/wht & pnk/wht. The colors are hard to see. I need to charge the battery & try it again.
Old May 8, 2011 | 10:47 AM
william_04_x's Avatar
william_04_x
If you're standing at the front of the truck, looking down on the connector/valve, from left to right: RD, BN/WT, LB/OG, GY/RD, WH/PK.
Old May 8, 2011 | 11:03 AM
wldcat65's Avatar
wldcat65
You should see pin letters on the plug. Here is the way they are connected.
Pin A - WH/PK
Pin B - GY/RD
Pin C - LB/OG
Pin D - BN/WH
Pin E - RD
If you hold the connector with the locking tab up pin A should be on the left.
Old May 8, 2011 | 12:55 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
After you get the wires reinstalled, (1) buy pellet gun!!!
(2) Reduce squirrel population
Old May 8, 2011 | 01:26 PM
william_04_x
The squirrel delete mod eh?
Old May 8, 2011 | 03:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I learned this trick after my engine harness had to be replaced..... they ain't cheap!
First tried humane ways and the squirrels decided I was stupid. Wally World had a sale on pellet guns.... Bud 100, squirrels 0 ..... who doesn't have a squirrel problem anymore?
Friartuck
Dec 1, 2010 02:57 PM
railbag
1997 - 2003 F150
Nov 7, 2010 07:52 PM
roadrash63
Jun 29, 2009 04:20 PM
b2_tim
Garage & Workshop
132
Jan 31, 2009 06:52 AM
PCTVFD
401, 477, & 534 SD Engines
Apr 22, 2008 11:36 PM
