is this MAF Sensor big enough?
Old May 5, 2011 | 03:49 PM
nstueve's Avatar
nstueve
Hey guys,
I got a 96 F-150 MAF sensor off a 4.9L I6 for $5... Figure I would chance it for the $5 that it might work on my 5.8L when I convert to MAF... Would it be big enough? I have everything from throttle body to the air filter box... Just wondering if it would work... I was thinking it might not be big enough but didn't know...
Thanks!
Old May 5, 2011 | 04:30 PM
73FOMO's Avatar
73FOMO
Do you know what size the maf is? The eec is calibrated for the specific maf on the truck....ie...mass airflow transfer corresponds with the maf for that particular application.
Old May 5, 2011 | 04:34 PM
SideWinder4.9l's Avatar
SideWinder4.9l
73-Have you cleaned out your inbox?
Sorry for the hijack Nathan.....
Old May 5, 2011 | 05:09 PM
nstueve's Avatar
nstueve
Does this mean if I get a A9L computer from a older mustang I have to use a 5.0L MAF sensor? JW...
Old May 5, 2011 | 05:10 PM
nstueve's Avatar
nstueve
73 probably needs to kick in his $20 and get the subscription to increase his inbox size... just a thought...
Old May 5, 2011 | 11:25 PM
Conanski's Avatar
Conanski
For best results you have to use the matching Mustang MAF.. but if you add a tuner you can then use any sensor you like as long as you can find the transfer function for it.
Old May 6, 2011 | 07:46 AM
nstueve's Avatar
nstueve
ok thanks paul!
Old May 6, 2011 | 09:27 PM
73FOMO's Avatar
73FOMO
Yeah....cleaned some of it out!
Old May 6, 2011 | 09:30 PM
73FOMO's Avatar
73FOMO
Pretty much unless you want to invest in equipment and want to learn how to tune.
I see Paul has answered...but just getting around to checking post today.
As Paul states you can tune any sensor with the right equipment...and you don't necessarily need the transfer function if you have a wideband and a datalogger to tune with.....but it gives the best starting point if you have the transfer function for it.
